1988 Chevy Suburban clutch
1988 CHEVROLET SUBURBAN
75,000 MILES • V8 • 4WD • MANUAL
SCOTTFREE
The problem I'm having with my truck is that it acts like the clutch isn't pushed all the way in although it's to the floor. I've tried the adjustement on the side of the transmission and it turns really easy and doesn't seem to have any effect.
Jun 1, 2010 at 1:55 PM
HMAC300
  • 48,601 POSTS
check to see if your fork that operates teh throw out bearing is worn out or bent. you'll have to getg a flaashlight and pull the rubber collar off and look throught the hole and see if you can see any wear. if you can't see it you'll have to pull the trans and bellhousing.
Jun 5, 2010 at 2:48 PM
