window wont roll up top wont open either
2005 CHEVROLET SSR
20,000 MILES • V8 • 2WD • MANUAL
SAMPRINCE
Drivers window stopped working and the top will not open as well?
Mar 23, 2010 at 9:25 PM
SQM
  • 6,383 POSTS
Check the fuse box in the rear, there is a relay for the folding top.
Do a visual inspection of the relay. Looks for any corrosion or burnt pin(s).
You can also test the relay:
If the relay is good, then the issue is either the module for the folding top or bad top power motor.
For the inoperative window motor check the fuse that is located in the under-hood fuse box.
Thank you.
Oct 5, 2021 at 11:59 AM
