headlights
1985 CHEVROLET SPRINT
ERINPEDREGON
My passenger side headlight is dimmer than the driver side. It is so dim I got a ticket for only having one headlight. I already replaced the headlight and it is still dim.
I went to the gas station and hed the mechanic adjust the headlight but that isn't the problem.
I unplugged the driver side head light and when I did it turned off the passenger side as well. So I than went and unplugged the (dim headlight) passenger side and it only turned off that side.
I had my roomate test the wires and they were ok.
I cant afford to take it to the shop So I must figure out what the problem is. If you can help me with any ideas on what could ne the problem, troubleshooting ect would be so appreciated. thank you
May 28, 2009 at 3:22 AM
SQM
  • 6,383 POSTS
One of common reason for dim headlight is having a corroded wire connector.
So, check the connector look for corrosion and burnt pins.
Here is a helpful video:
https://youtu.be/PxA5wczsCVo
Thank you.
Nov 15, 2021 at 10:32 AM
