Windshield washer pump doesn't work
CHEVROLET SILVERADO
NATEBYU
I have a 1988 chevy silverado 5.7 liter v8. 235000 miles C1500.
The windshield washer pump doesn't work. I replaced the pump a couple years ago. I also replaced the switch in the column and the whole column itself. The fuses look good. I checked the plug that goes into the pump for power while I held down the washer fluid switch and there is no power getting to the pump. I can't figure out why I am not getting power to the pump. I don't think it is the switch because I have had three different switches and I don't think it is a fuse because I tested them. What else could it be?
Oct 10, 2007 at 10:17 AM
BOOTDOG
  • 665 POSTS
check for loose an broken connections, also if your using a test light, make sure you have a good ground
Oct 11, 2007 at 4:27 PM
