Vehicle Speed Sensor problem?
CHEVROLET SILVERADO
2002 Chevy Silverado Z71 ext cab 5.3 150000 miles
ABS lights and Brake light came on then the speedo went off and transmission wouldn't shift. Got the comp scanned and it said vehicle speed sensor problem. I was told there was only one on the transfer case but I found two. Figured out which one was bad and replaced. everything worked fine then 3 weeks later same thing happened after getting off the interstate. If I turn the truck off for about 10 min and then drive it everything is fine until the next day of driving when i exit the interstate. Could there be another sensor or maybe I was sold a faulty part?
Aug 7, 2007 at 6:15 PM
[quote:d1cf7abdb0="[email protected]"]2002 Chevy Silverado Z71 ext cab 5.3 150000 miles
ABS lights and Brake light came on then the speedo went off and transmission wouldn't shift. Got the comp scanned and it said vehicle speed sensor problem. I was told there was only one on the transfer case but I found two. Figured out which one was bad and replaced. everything worked fine then 3 weeks later same thing happened after getting off the interstate. If I turn the truck off for about 10 min and then drive it everything is fine until the next day of driving when i exit the interstate. Could there be another sensor or maybe I was sold a faulty part?[/quote:d1cf7abdb0]
Not familiar with yours-but maybe it has one on the dash.
Aug 8, 2007 at 11:41 PM
