transmission
CHEVROLET SILVERADO
BONZPIPER
I have a 1994 chevrolet silverado 1500 4wd truck with overdrive. It suddenly stopped shifting into second and overdrive. There is no clutch material in the pan, and the truck runs good in the other gears. Someone told me about a shift solenoid on the transmission being bad, as it happened to them. I am thinking this may be the case. Is it located on the side(top) on the passenger side? Think that may be the problem? Where can I get one, or is it a "dealer item"? 5.7 liter (350) 117000 miles. Fluid levels good.
Sep 2, 2007 at 3:16 PM
2CARPRO JACK
  • 11,533 POSTS
I believe those are a dealer item.They are located in the valve body, you will have to have the pan off if it still isnt. Also have the dealer print you a diagram of which solenoid is which so you dont do the wrong one
Sep 3, 2007 at 8:51 AM
