'89 chevy c2500, 2wd, 200,000+, 3 speed automatic, 5.7 liter, am getting a growling or howling from underneath somewhere, while driving, not so much while idling or idling in gear, most of the time while taking off, it doesnt seem to want to go, and sounds like engine is over-reving before it kicks, when you do get to "drive" 40 mph is the best you get, and noise is louder, sometimes there are no problems or noise and drives normal, 50-60 mph, then will act up again, changed fluid, filter and gasket on tranny in august, was fine for a few days, now is worse than ever, and fluid does not look foamy or burnt. $700 for rebuild, cant afford this or the shop at this time, could it be the torque converter or is it the tranny, or something on rear of engine, rest of engine is fine(idle-revs) while parked.
Mar 18, 2007 at 8:10 AM
