power windows
CHEVROLET SILVERADO
CLOCO1930
  • 6 POSTS
1990 chevy 150000 miles v8 engine. i cant get my power windows to work and i cant find the fuse for it.
Feb 21, 2007 at 1:05 PM
CHEVY22
  • 1,375 POSTS
neither of them work , ???
Feb 21, 2007 at 1:10 PM
CLOCO1930
  • 6 POSTS
none of the windows work
Feb 21, 2007 at 1:11 PM
CHEVY22
  • 1,375 POSTS
fuse should be in the fuse panel in the truck , if you have a test light i would pull the master switch from the left door which just pops out just be careful there are tabs that break , and check for incoming power to the switch and then try power on the other side while moving the switch , if you have power to the switch and back out , next stop is the window motors
Feb 21, 2007 at 1:18 PM
CLOCO1930
  • 6 POSTS
what would the fuse be labeled as andwhats a test light
Feb 21, 2007 at 1:23 PM
CHEVY22
  • 1,375 POSTS
the fuse will be labeled windows , a test light is used to check for power it has a ground lead and the user end is fixed with a ligh and a probe , when its grounded and has power it pops the light on to tell you there is power at the source you are checking
Feb 21, 2007 at 1:26 PM
CLOCO1930
  • 6 POSTS
i dont have a fuselabeled windows in myfuse box unlessthere another fusebox in the car
Feb 21, 2007 at 1:29 PM
