MAF sensor
CHEVROLET SILVERADO
GRAYGHOST
  • 4 POSTS
I replaced my MAF with a performance cold air tuned MAF. Afterwards, my air conditioner was blowing hot air like the heat was full on. Performance wise I noticed an obvious increase in performance while driving, but obviously I couldn't use my AC.
I reinstalled the stock MAF, and my AC is back. How could the MAF affect the AC? Does this point to a partially malfunctioning MAF, or is something else need to be tweaked?
I have a 2005 Chevrolet Silverado Crew Cab 4x4 5.3L VIN T engine with automatic transmission with a K&N FIPK installed. I have just shy of 50K miles on it.
Aug 25, 2007 at 6:12 PM
2CARPRO JACK
  • 11,533 POSTS
I have never heard of a MAF having an effect on the A/C.They are 2 different systems. I would try it again just for laughs, if A/C still doesnt work, call the tech line of the company who makes the MAF and hit them up on it, doesnt make any sense to me at all
Aug 26, 2007 at 8:17 AM
Outbox :: Message
To: GrayGhost
Posted: Sat Aug 25, 2007 6:46 pm
Subject: MAF
quote="GrayGhost"]I replaced my MAF with a performance cold air tuned MAF. Afterwards, my air conditioner was blowing hot air like the heat was full on. Performance wise I noticed an obvious increase in performance while driving, but obviously I couldn't use my AC.
I have a 2005 Chevrolet Silverado Crew Cab 4x4 5.3L VIN T engine with automatic transmission with a K&N FIPK installed. I have just shy of 50K miles on it.[/quote]
This one is hard I'll try my best on it
Is it 1500/2500/3500? their road maps in circuits are entirely different is it a Hybrid model.
Try disconnecting the MAF sensor when engine fires up feather it and keep it running while you turn the AC ON. Is it coming On.
I've spent nearly 45mins to tie this 2 together and they got nothing in common. Did you disconnect the battery by any chance?
One thing for sure it has a lot of sophisticated electronics. And its giving me bananas trying to find it. I know its not your problem,am giving it all I got.
Airflow going thru the engine has nothing to do with the AC-Am begining to think that IAT on the Alowmeter is tied in with the AC temperature devices I hope not-never heard of such thing.
_________________
Problems solving-Did you gave us everything we need to know before we start. Tell us a little story about it if you have to. And please stay in one problem one at a time and on the same post-Thank You
Aug 26, 2007 at 5:30 PM
Maybe it needs a computer relearning or reflash to get its programmed signal- The compressor is controlled by the PCM-and I really don't know how the MAF is tied in with the AC to be causing the problem
PM
To: rasmataz
Posted: Sun Sep 02, 2007 8:14 am
Subject: Re: MAF
This is what I found out, but I'm not sure of its accuracy. Sometimes when the battery is unhooked the AC will go out. If you disconnect the battery for a minute and then reconnect it, the computer will reset and give you back your AC
Sep 2, 2007 at 7:17 PM
