I have a 1997 chevrolet 3/4 ton pu and replaced the fuel pump several times it has 205000 miles and now when I first try to crank it it acts as if the fuel pump is not working. If I leave the key on for 1 1/2 to 2 minutes it will try to start and after a few attemps of this procedure it will crank and run fine. Is there some sort of pressure switch or regulator that could be bad?
Nov 19, 2007 at 1:10 PM
