computer problems
CHEVROLET SILVERADO
FASTEDDIESWOMAN
1995 GMC Silerado full throttle engine
when you take off it is fine til you come to a stop then start again it starts acting like it is going to die it keeps stalling. There is no check engine light and once it would not start til my boyfriend mess with it for a few mintues the next day then it finally started but it is getting worse he got a tune up on it replaced the spark plugs and wires replaced the fuel filter and used carborator cleaner on it but that still did not fix the problem if it is the brain box can i get a price for a new one? and where it is located on the truck and if it would be hard to change it?
Aug 15, 2007 at 6:29 PM
MIKE H R
  • 3,094 POSTS
ecm s are not hard to change, it is located under the dash on the passengers side. it is held in with two screws. Try first to reset the computer. Disconnect the negative side of the battery. Leave it off for about 10 minutes. Reconnect it. The computer will not reset itself right away and will have to be driven for about 50 miles to completly reset. A new computer is expensive, you can try to get one out of a junk yard, but there is no garantee it will work, as they say buyer beware.
Aug 15, 2007 at 6:43 PM
