brake rotor removal
CHEVROLET SILVERADO
THOMASWA
I have a 1996 2500 a Silverado HD with 5.7L 191000 miles. I have been unable to remove the rotors. I have removed the outer nut on the Hub/spindle. I know I will need to remove the studs from the hub and rotor assembly after the hub spindle has been removed.
May 24, 2007 at 8:50 AM
SERVICE WRITER
  • 9,123 POSTS
2wd-should slide right off, 4wd you need a puller.
May 24, 2007 at 9:24 PM
