alternator/battery issue
CHEVROLET SILVERADO
AUGGIE441
I have 94 silverado, 1500, V6. Replaced alternator - was bad-bearing noise and battery indicator was 8 amp. Charged battery, befor installing alternator. Two days later, battery indicated spikes and headlights, instrument, dome lights flickered. Replaced battery with new one. Same issue with lights flickering and battery indicating spikes. Both alternator and battery test within the range. Could it be an intermettent problem with the voltage regulator in the alternator? Under load from headlights on and heater fan on, really spikes bad on the battery indicator.
Feb 27, 2007 at 10:01 AM
A-TRAIN
  • 6 POSTS
if the problem didn't exist before, I'd double check all the alternator connections first, 'cause it sounds like a short or a loose ground to me
Feb 28, 2007 at 11:18 PM
