4l60e tranny
1960 CHEVROLET SILVERADO
RICK74631
the rebuilt valve body has every thing new in it new gaskets new spacer plate new screen it shift fine for a block and i stop and took off again and shift fine the first shift the second shift nothing
Sep 27, 2007 at 5:46 PM
DENNYP
  • 1,824 POSTS
[quote:73bad5ea86="rick74631"]my truck would not shift right in d-3 gear it would shift fine the frist time the second shift it would hang up in the shift so some in here told me i need a need shift solenoid so i just bought a rebuilt valve body and put it all to gether and took it for a test drive for a block it shift like it use too but on the way home i stop at i stop sign and when i took off it shift fine when it went to shift again it did not shift the same as the old valve body did i did not change the wire harness and the lock up solenoid should i replace them too[/quote:73bad5ea86]
you might try checking the valve body spacer plate for any small metal debris in the passages. theese transmissions are prone to excess casting material plugging up restricter holes in the spacer plate.
Sep 27, 2007 at 10:57 PM
