2008 Chevy Silverado P0171 and P0174 after engine replaceme
2008 CHEVROLET SILVERADO
62,000 MILES • V8 • 4WD • AUTOMATIC
SICKOFTHEMIL
I'll try to keep this short.
A few weeks ago while traveling, my engine dropped a valve under warranty. A bunch of white smoke later (I assume a compromised combustion chamber) it was flatbedded to the nearest dealership. The dealership replaced the engine under the Powertrain Warranty - so far, so good. Since I live about 3 1/2 hours away from where the truck died, when it was complete I had to pick it up on a Friday night after hours. I got in it, drove 30 miles or so, and the check engine light came on - P0171 and P0174.
On Monday, I called the dealership (remember, 3 1/2 hours away) who informed me the problem was emissions related and NOT under warranty. I won't bore you with the details of arguing with "customer service" reps that one thing probably led to the other...but I'll get to where I am now.
I had the engine scanned at a local dealer, where I was told both the upstream O2 sensors were bad...to save a few dollars, I replaced them myself.....Same Problem. I signed up for the Mitchell manual, and started through the diagnostics. Thus far, I've replaced not only the O2 sensors, but the MAF and MAP sensors as well. I still get the same codes. I was able to borrow an inexpensive scanner, and here's what the freeze frame is showing:
B1 - Closed Loop, using HO2S
B2 - Closed Loop, using HO2S
Calculated Load 11.76%
Coolant Temp 89 degrees C
ST Fuel Trim B1 6.23%
LT Fuel Trim B1 29.67%
ST Fuel Trim B2 10.14%
LT Fuel Trim B2 29.67%
MAP 41 KPa
Engine Speed 1077.50 RPM
Vehicle Speed 59 Km/hr
Ignition Timing29.50 BDTC
MAF 4.82 g/s
TPS 21.56%
I'm pretty much at a loss where to look next....any help would be appreciated! I was supposed to leave on vacation today, so I have a pretty displeased wife!
Jun 28, 2010 at 11:48 PM
Lean fuel condition could be caused by one of the following below:
1.Vacuum leaks
2.EGR and PCV valve.
3.Low fuel pressure.
4.Dirty fuel injectors.
5.Mass Air Flow Sensor.
6.Oxygen Sensor.
Jun 29, 2010 at 12:06 AM
