Hi dhuscha, Welcome to 2carpros and TY for the donation
Remove or Disconnect
Negative battery cable.
Instrument panel compartment.
Front screw from right door sill plate.
Right hinge pillar trim panel.
Electrical connectors from PCM, as necessary.
PCM and mounting bracket (diesel engines only).
Electrical connectors from blower motor (60), as necessary.
Bolt from right lower I/P support.
Blower motor cover.
Blower motor cooling tube.
Blower motor flange screws (59).
Blower motor (60).
Pull the blower motor forward carefully to avoid distorting the blower fan.
May be necessary to pry back right side of instrument panel.
Apr 30, 2021 at 3:33 PM
(Merged)
