hello, my chevy truck started making a squealing noise only once warmed up, and only in gear while cruising, if you let off the gas it goes away, if you put on the gas it goes away. It will make it at almost any rpm, but only while cruising. It will not make the noise in park, neutral, I think it maybe associated with the tranny since if you put it in neutral while cruising the noise goes away, It shifts fine, and is full of new fluid. The noise is pretty loud.
Nov 14, 2009 at 9:26 AM
