Hi, hoping you can help. Here's what i know.
I do not have the service 4wd message at the DIC. I can here the transfer case shifting between 4hi, 2wd, 4lo. When in 4hi, the front driveshaft is locked, the front axles are not, they spin free. When in 4lo, it definitley goes into low gear but same problem as above, front axle not engaged. I've pulled the wiring harness at the front diff actuator. I get voltage at the brown wire and no where else when in 4hi. Should i get a reading at a different location or is a 1 time signal sent to the actuator, so i need to be reading voltage at the time of the shift? Or is my reading above correct and i simply need a new actuator.
Thanks
Thanks
Dec 12, 2009 at 9:49 AM
