I have the following symptons. 1. the airconditioner stops working correctly,blows hot air driver side and cold passanger side, 2. check Engine light will not reset, code reader does not read ECM fuse is not blown. 3. fuel down from 24 to 17mpg.
How do i check the computer to determine if it truely is bad, or are the symptons seperate problems that a new computer will not fix then What programming do i really need if i change the computer myself.
May 25, 2010 at 7:35 PM
