my head lights are stuck on all of the time. i was charging the battery and also soldering some wires under the fuse box under the hood. when i tuched the soldering iron to one of the wires (i think one of the ones from the fog light relay) it sparked. immediately the lights came on. (I think that the current from the charger found a path through the soldering iron to ground) i tried to turn them off with the controls in the cab and but that did not help. even with the light control in the off position and the key removed the lights stay on. the only way to turn them off is to remove the fuse or relay.
did i blow the BCM?
did i blow the BCM?
Aug 25, 2009 at 3:36 PM
