2004 Chevy Silverado fuel cap
2004 CHEVROLET SILVERADO
80,000 MILES • V8 • 2WD • AUTOMATIC
TEXASPEACEOFFICER
my check engine light indicating my fuel cap needs tightening keeps coming on. I have replaced the old fuel cap with a new one, but when my tank has about 1/4 left, the check engine light comes on telling me my fuel cap needs tightening. How do I fix this??????
Oct 8, 2009 at 1:17 PM
SERVICE WRITER
  • 9,123 POSTS
the light is detecting a loss of fuel vapor, not necessarily the fuel cap. The code is po442 maybe?
This means that there may be leak elsewhere in the evaporative system such as a fuel filler neck for example.
Verify what code # is there and get back to me.
Oct 8, 2009 at 1:41 PM
TEXASPEACEOFFICER
the code is po455
[quote:a5eda2f37e="Service Writer"]the light is detecting a loss of fuel vapor, not necessarily the fuel cap. The code is po442 maybe?
Verify what code # is there and get back to me.[/quote:a5eda2f37e]
Oct 14, 2009 at 10:06 AM
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_evap_3.jpg
This is a large leak, and a vacuum can not be drawn on the evap system. Check the connections as per the drawing to make sure a hose is not off or damaged. A valve stuck open will also do this. IF none, you can either have the system smoke tested or pull off the vent valve and check for any dirt inside of it. Replace if so. Why so many different user names? https://www.2carpros.com/forum/modcp.php?mode=ip&p=689171&t=357139&sid=e3bce73e7d2f32702cf386a99e09382d
Oct 14, 2009 at 1:08 PM
