Dandy answer.
If it helps, the Engine Computer is watching the switching rates of the O2 sensors. The front ones switch from "rich" to "lean" about two times per second. If the catalytic converter is working properly, the rear O2 sensor will switch perhaps as little as once per one or two minutes. As the converter loses its efficiency, the rear O2 switching rate becomes faster and faster, approaching the same switching rate as the front sensors. At some point the software decides, based on the increased switching rate, the converter is not as efficient at cleaning up the exhaust gas as it needs to be, then it sets one of the codes you listed. That catalyst monitor has no idea of the engine size. If you're using the original computer with the original O2 sensors, the only thing that will be different is exhaust gas volume, but there's nothing measuring that. You can't even say that's measured by the mass air flow sensor because exhaust gas is very hot and has expanded a lot.
May 6, 2021 at 1:53 PM
(Merged)
