Hello, looking for some help / advice for my 03 Silverado
About a month ago, my 03 started getting a rough idle when sitting at a stop light,( SES on)
Took it to a GM dealer, they checked the codes, It had PO131, PO171, PO174, PO300, P1133, They said I needed intake gaskets, and Bank1Sensor1 O2 sensor.
I replaced the intake gaskets with a FelPro set, Replaced the Bank1 Sensor1 O2, Cleaned MAF, changed fuel filter.
Still no good, I am still getting PO171, PO300, and now the P1133 came back. I have cleared codes several times, The PO171 pending comes back within seconds, and after a few minutes the PO300.
Still running rough, Leaves black soot under the tailpipes, fuel mileage dropping .
I have tried looking for bad vacum hoses, they all seem ok, Tried spraying carb cleaner around new intake gaskets, Throttle body o-ring, Intake pipes,and all vacuum hoses, Nothing.
Fuel pressure is 54 with Key on
48-49 at Idle
48-49 at 3000 rpm
58 If I snap the throttle hard.
Codes from cheapy code reader :
PO171, PO300, P1133
PO171 pd, PO300 pd
Monitors 3 inc. Catlyst, Evap, O2 sensor
4 Ready. Misfire, Fuel, Comp, O2 HTR
Got a vacuum gauge today.
Connected to the PCV port I am getting a steady 17 in, with only a Vary, vary slight fluctuation, maybe 1/2 in, or so.
With the gauge connected to the PCV port, engine runs smooth, at a normal idle. When I reconnect the PCV valve the rough idle returns.
Any ideas would be appreciated
Thanks
I can donate more money tomorrow, Need to put money in the bank, Right now there is only $ 6.00 in there.
48-49 at Idle
48-49 at 3000 rpm
PO171, PO300, P1133
PO171 pd, PO300 pd
Thanks
Feb 15, 2010 at 7:29 PM
