2003 Chevy Silverado Passenger door electrics and keyless e
2003 CHEVROLET SILVERADO
86,000 MILES • V8 • 2WD • AUTOMATIC
JTMERRITT3
The passenger door locks and window controls in my Silverado have stopped operating. At the same time, my keyless entry stopped working. I would have thought this coincidental, but have found similar complaints online. I have tried checking for a blown fuse, but cannot determine which fuse/ relay might be at fault. I cannot decipher the acronyms on the diagrams.
Jan 15, 2009 at 11:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello Thanks for the donation. I have the fuse acronyms listed below for you. Post the results of the fuse/relay inspection and I will follow up. Below is the legend for your fuses in interior fuse panel.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_139.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_46.jpg
Below is the legend for under hood power distribution center.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_140.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_47.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_141.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_48.jpg
Thanks for using 2CarPros.com!
Jan 16, 2009 at 1:23 AM
JTMERRITT3
[quote="jtmerritt3"]Electrical problem
2003 Chevy Silverado V8 Two Wheel Drive Automatic 86000 miles
The passenger door locks and window controls in my Silverado have stopped operating. At the same time, my keyless entry stopped working. I would have thought this coincidental, but have found similar complaints online. I have tried checking for a blown fuse, but cannot determine which fuse/ relay might be at fault. I cannot decipher the acronyms on the diagrams.[After a few more days, and exhausting all possible fuses, I've also discovered that the interior light no longer responds to the door (nor do the lights on the door light up when opened), the "passeneger door ajar" alarm on the dash does not respond to an open door - essentially it's as if the car forgot the passenger door ever existed. I'm lost ]
Jan 28, 2009 at 7:20 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Have you done or had any repairs made to vehicle recently?
Try spraying some WD-40 on the door ajar switch for that door. Sounds like it is faulty . Post results and I will follow up.
Jan 29, 2009 at 12:02 AM
JTMERRITT3
[quote="bluelightnin6"]Have you done or had any repairs made to vehicle recently?
Thanks for using 2CarPros.com![No repairs - left for the holidays and came back to the problem. Maybe it was like that a couple days before I left but I never noticed. I don't enter from the passengers side too often. The WD-40 does not appear to have changed anything. Is it possible that a connection has dislodged or a short is causing this. Seems electronic, - everything that is wrong is connected to that door in some way. ]
Jan 30, 2009 at 12:23 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay, lets try this. Disconnect your battery and leave cables off for 10 - 15 minutes then reconnect battery. See if this helps the situation. Let me know what happens and I will keep digging for some more troubleshooting procedures.
Jan 31, 2009 at 12:06 PM
SHEREDA33
I have had the same problem and have tried everything u have said. Is there anything else to try?
Jul 26, 2009 at 12:53 PM
