No power (or ground?) to driver's door
2003 CHEVROLET SILVERADO
100,600 MILES • V8 • 4WD • AUTOMATIC
SAMBAL BADJAK
  • 20 POSTS
I left my truck outside at the airport all last week and when I came back, nothing electrical in the driver's door worked. I had to unlock it with the key although two clicks on the remote unlocked the other doors. The power mirrors, windows, locks, seat heaters and dome light were inoperative from the driver's door. About 10 minutes into the drive home, I noticed it all started working again (door switch illumination came on). I stopped for dinner and came out 45 minutes later to find nothing worked again. Three days later, still nothing works. I don't have a wiring schematic to see where the ground is located, or if these accessories run through a multiplexer, or know where to begin. Any help would be appreciated.
Sep 28, 2009 at 2:14 PM
JDL
  • 16,098 POSTS
Welcome to the forum. There should be a left door circuit breaker in the lt i/p fuse box, use testlite, one of those legs should be hot all the time.
Sep 28, 2009 at 2:35 PM
SAMBAL BADJAK
  • 20 POSTS
[quote:e42a703ec4="jdl123"]Welcome to the forum. There should be a left door circuit breaker in the lt i/p fuse box, use testlite, one of those legs should be hot all the time.[/quote:e42a703ec4]
I read 12 volts at the breaker and less than 1 ohm through the breaker, so I have power and the breaker should be good.
Sep 28, 2009 at 2:49 PM
JDL
  • 16,098 POSTS
Orange wire from that circuit breaker carries voltage to the driver door module, inside the door. On some makes and models, I have accessed the wiring at the front side of door, where the wiring harness goes in. Maybe you can access the circuits on the backside of window switch?
Sep 28, 2009 at 4:00 PM
SAMBAL BADJAK
  • 20 POSTS
[quote:2311a2172e="jdl123"]Orange wire from that circuit breaker carries voltage to the driver door module, inside the door. On some makes and models, I have accessed the wiring at the front side of door, where the wiring harness goes in. Maybe you can access the circuits on the backside of window switch?[/quote:2311a2172e]
I'll pull the door panel and check voltage inside. I'll let you know what I come up with.
Sep 28, 2009 at 5:02 PM
SAMBAL BADJAK
  • 20 POSTS
[quote:a3ee000612="jdl123"]Orange wire from that circuit breaker carries voltage to the driver door module, inside the door. On some makes and models, I have accessed the wiring at the front side of door, where the wiring harness goes in. Maybe you can access the circuits on the backside of window switch?[/quote:a3ee000612]
I pulled the door panel. There are 3 orange wires that come into the door. I am assuming the main power is the thicker of the three - 14 ga. maybe. It is in a 4 socket connector (blue, orange, brown and black). The orange is 12.5 v and black is ground. I don't know what brown and blue are.
Sep 28, 2009 at 5:44 PM
JDL
  • 16,098 POSTS
Brown is up voltage and blue is down voltage for the window motor. I may have that backwards, but, when brown is voltage blue is ground, when blue is voltage brown is ground, because it is a reversing motor for up and down.
Sep 29, 2009 at 11:00 AM
SAMBAL BADJAK
  • 20 POSTS
[quote:2b53f7dd0c="jdl123"]Brown is up voltage and blue is down voltage for the window motor. I may have that backwards, but, when brown is voltage blue is ground, when blue is voltage brown is ground, because it is a reversing motor for up and down.[/quote:2b53f7dd0c]
Makes sense. Is there a multiplexer or control module for everything in the door? I have power to the switch, but nothing works - mirror, seat heat, switch illumination, windows, power locks, door light or dome light when door is open. The other windows open from their respective doors, power locks work on other 3 doors from the fob and dome lights work from the other 3 doors too.
Sep 29, 2009 at 11:07 AM
JDL
  • 16,098 POSTS
There is the driver door module that goes out in these cars, here is a full wiring diagrams for the door module and locks.
Please let us know what you find.
Cheers
Sep 29, 2009 at 11:57 AM
SAMBAL BADJAK
  • 20 POSTS
Yep I replaced the drivers door module and it fixed the problem you guys are great!
Sep 29, 2009 at 1:45 PM
GREGLANE
I have a similar problem on my 2003 Silverado. However, my dome light stays on and the Driver Door Ajar message is displayed. I'm guessing it is a broken power wire. Any confirmations? Makes s sense to me that power has to go through the door switch and back to the inside of the cab. Where exactly is the door switch? Tomorrow, I will use a meter and check for power in the door.
Mar 9, 2018 at 5:30 PM
It is the driver side do0r latch which is on. The micro switch inside the latch has gone bad, here is a guide to help you get the door latch changed out.
You will need to remove the door panel this should give you an idea of what you are in for.
https://www.2carpros.com/articles/door-panel-removal
Mar 12, 2018 at 12:42 PM
SHANNA HORNER
I'm also having these problems.. I will say, if I completely open the driver door, everything works, but as soon as... I start to close it, I lose all power.
Mar 9, 2020 at 5:36 PM
This is typical when a wiring harness gets pinched or grounded. So when you remove everything, it works because the wiring issue is no longer touching the grounding location like a bolt, nut, or other piece of metal.
I would suggest removing it again and checking the wiring as far as you can see it. If you don't find any wiring issues then you may have to remove the wiring to inspect it.
Mar 10, 2020 at 7:24 AM
ALEX BUCHINGER
I just replaced my door hinge pins and now I don't have any power to my drivers door. Power came back for a brief moment and haven't come back, it doesn't matter of the door is open or closed. I'm not sure if the harness went bad for who knows why.
Jun 20, 2020 at 5:37 PM
Okay. Let's do one of two things. First either let me know the year, make, model, engine of your vehicle or just get a new post started of your own.
I suspect you have a short in the wiring harness and have now blown a fuse but we need to get the vehicle specifics in order to track this down.
Let us know and we can go from there. Thanks
Jun 21, 2020 at 7:27 PM
ALEX, is your problem on the same truck? if so we will continue on this thread.
Jun 22, 2020 at 10:25 AM
Thanks Ken. I just re-read my post and that is what I meant but what I said didn’t communicate that.
Thanks for clarifying it. Sorry for the confusion Alex.
Jun 22, 2020 at 10:30 AM
MCOLA77
  • 4 POSTS
I have a 2003 Chevy Silverado and I hooked up one of the LED light strips under the tailgate blinker, brake and reverse in one. I went to turn on everything and my blinker was on like the flashers then hit the brakes the right brake light doesn't come on that's on auto. Turn the light on manually right blinker doesn't work same with no right brake light turn everything off but turn your ignition to on I have no brake lights, but I have blinkers. Now getting to my driver's door has no power, but I can operate the passenger door from the driver's. Now the PDM fuse is in the same fuse block as the brake, and the blinkers and it keeps blowing the fuses put in instantly. Did I fry that whole fuse block under the dash?
Dec 29, 2021 at 12:31 AM
MCOLA77
  • 4 POSTS
I took that LED light strip out and didn't change a thing either.
Dec 29, 2021 at 6:39 AM
You definitely have a short and based on the fact that all you did was install this LED strip then I suspect that is the case.
In fact, you have a flasher module within the left IP fuse box that is most likely the issue.
Basically, we need to remove the fuse and test for a short.
I am attaching the wiring diagram that will show this the detail needed.
Let's run through this and confirm where the short is and we can go from there.
Another way to eliminate everything but the fuse block is to just disconnect the connectors and check for the short to ground.
Let me know if you have questions on this.
Thanks
Dec 29, 2021 at 1:14 PM
MCOLA77
  • 4 POSTS
I opened up that whole wiring harness following both light blue and both dark blue wires for the brake lights and blinkers. The problem is between both fuse blocks. Are you talking about that big lo g flasher relay that's $75.00, lol. I bought one of them already too l ever took apart the fuse block under the dash to see if anything was burnt it looked good.
Dec 30, 2021 at 12:48 AM
Just to be sure we are on the same page, but it sounds like we are, I am attaching the info below on this flasher module.
However even if you replaced that and traced the wires, we are still dealing with a short. Anytime a fuse blows as soon as you put it in, we have a short to ground prior to the load in the circuit. Basically, we need the load (light bulb, module, actuator, or whatever is getting powered) to use the voltage so that the current is used as well. If we don't then the current racing through the wire creates heat and that will melt the wiring or blow the fuse.
So, I understand you inspected the wiring but let's check it for a short to ground with a meter or test light and that will tell us for sure. Or you can just run a new jumper wire and see if the fuse stops blowing. Sometimes you cannot see the pinched wire, so it is missed.
Dec 30, 2021 at 7:25 AM
MCOLA77
  • 4 POSTS
Yes, everything worked until putting stuff back together that one in the morning. I'm going to test, and jumper wire it today between dash and under the hood Fuse block to where it come out on the frame, I'll tough base later on.
Dec 30, 2021 at 12:58 PM
Sounds great. Thanks for the update. We will wait to hear back. Thanks
Dec 30, 2021 at 6:59 PM
