2001 Chevy Silverado SHOCK BRACKET MOUNT
2001 CHEVROLET SILVERADO
129,000 MILES • V8 • 4WD • AUTOMATIC
LAMEHANDLE0_1
The part welded to my rear axle (i'll call mount) that attaches the lower end of my shock absorber is twisted. It needs to be ground off and replaced unless I can whack it back into shape. It probably happened when I was stuck half tipped over in a ditch with that area contacting the edge of the pavement or when I ran over a boulder plowing. . Nonetheless, the shock doesn't line up like that, it has broken off there and is hanging from the upper one. Is there somewhere on the internet I can find and purchase a new one or set ? All I've seen is similar mounts that are lowering or raising kits but nothing for original replacement.
Oct 8, 2010 at 4:33 AM
If it is available, it will be a dealer part. As far as the one on the vehicle, if you heat it, do you think you could straighten it?
Oct 8, 2010 at 11:38 PM
LAMEHANDLE0_1
[quote:a8902684f5="Jacobandnickolas"]If it is available, it will be a dealer part. As far as the one on the vehicle, if you heat it, do you think you could straighten it?[/quote:a8902684f5]
Thanks very much. I think it's worth a try if I'm gonna cut it off anyway. My cousin is an autobody guy lookin' into it fir me too.
Oct 11, 2010 at 1:28 PM
Let him have a go at it. Chances are if he has the torches to heat it, he should be able to get it back into position.
Oct 11, 2010 at 1:36 PM
