2001 Chevy Silverado obd II codes
2001 CHEVROLET SILVERADO
11,500 MILES • V8 • 4WD • AUTOMATIC
RRCONDUCTOR
my 2001 silverado shows 2 codes,P0200 and P0300. i would like to know what has to be done to correct these error codes? thank you,allen
Feb 9, 2009 at 11:14 AM
JDL
  • 16,098 POSTS
Does the vehicle start and run? P0200 means injector circuit open, that might mean all of them.
The P0300 is a random misfire, usually a problem common to all cylinders. I'd check the injector issue first. B+ to the injectors goes hot with the key on. Now if the computer isn't grounding the injectors, that's another issue.
Feb 9, 2009 at 3:31 PM
RRCONDUCTOR
yes it does start and run and idles,but misfires a little when give it the gas.
Feb 9, 2009 at 3:59 PM
