All relays and fuses good.
Seat belt light only flickered til I disconnected battery.
Did not do it again, upon reconnecting.
Problem Solved though.
The cable was corroded under the rubber boot Chevy puts on the positive cable. After cutting off the boot and inspecting soaking/scrubbing with diet Pepsi (Didn't want to waste a regular Pepsi) til it stopped bubbling, rinsed, wiped dry. Reinstalled cables (left off boot), while tightening cables on, lights started to come on, sounds started sounding. Turned ignition to off, pulled key, put key back in, started truck.
I'm not putting boot on because, my father always put grease on the posts and cable ends to keep corrosion from forming.
Check those cables people!!
Thank You
Nov 30, 2008 at 3:57 PM
