2001 Chevy Silverado Hot Air
2001 CHEVROLET SILVERADO
95,000 MILES • V8 • 4WD • AUTOMATIC
RED3868
Sometimes when I turn my temp. selector to hot and then return it to the cooler sitting I still have hot air blowing from the vents. Now if the truck sets over night everything works fine. But while the truck is running or throughout the day I can turn the air cond. on and it will still blow out hot air. But like I said, after it sits over night it usually works great and the air is cold. I have been told it's a sensor, which is located behind the glove box? If it's a sensor where is it and what is it called and can I replace it?
Thanks
Nov 1, 2010 at 1:05 PM
Have you checked the blend air door? It sounds like it is sticking.
Nov 1, 2010 at 1:21 PM
RED3868
Where is the blend door located at?
Nov 1, 2010 at 1:30 PM
It is part of the HVAC system and next to the heater core. It is what determines if you get AC or heat.
Nov 1, 2010 at 1:34 PM
