2000 Z-71 wont shift to overdrive after rebuild
2000 CHEVROLET SILVERADO
BOOZERLOVE4
I have a 2000 Chev Silverado Z-71 5.3 with 170K. original owner. Recently lost reverse, 2nd,and overdrive after loud violent noise. my mechanic replaced sun shell and torque converter. everything worked fine except won't shift to overdrive. Tech II shows everything good. No codes.(Before or after repair) . He then removed valve body to bench for thorough inspect and cleaning. appears fine. Became frustrated. Replaced all selenoids. Still no difference.
Any advice would be much appreciated.
This truck has tow/haul switch which I have brought up a couple of times but been told not a possibilty.
Sep 6, 2007 at 10:41 PM
2CARPRO JACK
  • 11,533 POSTS
It is a possibility... that switch keeps the truck out of OD while towing. Has the shop verified the switch works?
Sep 7, 2007 at 7:56 AM
