having a problem w/ either the window switch or the window motor. when the switch is pressed to raise/lower there is a clicking noise from a relay but no window movement. I suspect a fuse might be the problem but which one?
thanks, Carter
thanks, Carter
Jan 12, 2006 at 11:15 AM
