I just bought a 2000 Silverado with a 4.8 and am having problems. It occasionally shows a check engine light for rear 02 sensor low voltage and it has almost no power when cold and low end is always weak. It takes about 10 seconds to get through 1st gear. It has no misfire and every once in a while it will pull really hard like it should.
I have:
Changed plugs
Used a can of Seafoam
Poured 2 cans of B12 into a full tank
Cleaned the EGR, IAC, and throttle body
Replaced a rear oxygen sensor (light still shows bank 1 and bank 2 rear sensors)
Checked fuel pressure (holds at 55 psi)
Changed fuel filter
Fixed a cracked line going to pressure regulator
Replaced the pressure regulator and intake gaskets
The intake gaskets seem to have helped but there is still somethng wrong. It has a tiny surge while idling, but not enough to show on the tachometer. Also, the check engine light only comes on at highway speed and full throttle. Here is a freeze frame:
Code P0137
100% throttle
3399 RPM
35.6% Engine Load
79.23 GR/Sec MAF
MAP sens 98 KPA
Coolant temp 199*
Short term fuel trim 1 0.8%
Long term trim 1 24.2%
Short term trim 2 0.8%
Long term trim 2 23.4%
Short term trim 3 -96.7%
Long term trim 3 -55.1%
Short term trim 4 -89.7%
Vehicle speed 80 mph
Fuel system 1 OPEN1
Fuel system 2 OPEN1
Thank you
I have:
Changed plugs
Changed fuel filter
Code P0137
100% throttle
3399 RPM
35.6% Engine Load
79.23 GR/Sec MAF
MAP sens 98 KPA
Coolant temp 199*
Fuel system 1 OPEN1
Fuel system 2 OPEN1
Thank you
Aug 3, 2009 at 2:27 PM
