2000 Chevy Silverado truck starts then stops
2000 CHEVROLET SILVERADO
155,000 MILES • V8 • 4WD • AUTOMATIC
ROCKLOS1
  • 6 POSTS
truck starts but shuts off, ive replace fuel pump a few month ago right now its doing 55-60psi key on, changed the crank position sensor, fuel filter, regulator, still nothing, no codes on scanning computer. need help to get going?
Jul 7, 2008 at 2:21 PM
Try feeding it with carb cleaner continuously does it continue to run if so test the oil pressure sending unit-
Jul 7, 2008 at 3:03 PM
ROCKLOS1
  • 6 POSTS
it does run with staring fluid or carb cleaner, i also was told to check the injector for a pulse and nothing there.
Jul 7, 2008 at 4:49 PM
Could be that the computer is not receiving the ignition reference signal therefore its not energizing the injector/s or a problem with drivers in the computer or power to the injector/s-
Jul 7, 2008 at 6:21 PM
ROCKLOS1
  • 6 POSTS
thanks for the help your giving me, i just picked up a pcm from a bone yard and still the same, starts and stops???
Jul 7, 2008 at 6:56 PM
Try this use direct power from the battery to the fuel pump connector gray wire-
Jul 7, 2008 at 7:06 PM
ROCKLOS1
  • 6 POSTS
is there any other place to catch that grey wire or do i have to tie in at the fuel tank.
Jul 7, 2008 at 7:58 PM
You can power it thru the fuel pump terminal of the diagnostic connector if it has the terminal
Jul 7, 2008 at 8:52 PM
ROCKLOS1
  • 6 POSTS
ok i powered it though the main fuse panel theres a prim connector and added the 12 volt heard it humming and cranked the key a few time and still nothing, i do have a pressure gauge on the rails and its doing 58 psi.
Jul 7, 2008 at 9:05 PM
Crank engine over while listening to the injector/s are they clicking meaning its pulsing
Jul 7, 2008 at 10:18 PM
ROCKLOS1
  • 6 POSTS
i put i test light to it and no flashing.
Jul 8, 2008 at 4:38 AM
Did you check injector A and B fuses 15amps, also check the camshaft position sensor in the distributor this is the one that synchronizes the injectors-
Jul 8, 2008 at 3:48 PM
ROCKLOS1
  • 6 POSTS
fuses good, truck is 2000 and it doesnt have a distributor.
Jul 8, 2008 at 5:02 PM
