2000 Chevy Silverado throttle hangs
2000 CHEVROLET SILVERADO
147,000 MILES • V8 • 4WD • MANUAL
DANNY GRIFFIN
I have a 2000 model 4.8 litter 5 speed 1500 chevy when and only when I used the A.C. unit the throttle will stick. When I go to change gears the clutch is depressed the r.p.m. will not drop and sometimes will even go up. This only happens durning the summer. No engine lite has come on. Had the throttle body cleaned. Has not happened durning winter while a.c. unit is off.
Jan 3, 2008 at 12:26 PM
FISHERMAN
  • 937 POSTS
[quote:50a0959f97="danny griffin"]Other Category problem
2000 Chevy Silverado V8 Four Wheel Drive Manual 147000 miles
I have a 2000 model 4.8 litter 5 speed 1500 chevy when and only when I used the A.C. unit the throttle will stick. When I go to change gears the clutch is depressed the r.p.m. will not drop and sometimes will even go up. This only happens durning the summer. No engine lite has come on. Had the throttle body cleaned. Has not happened durning winter while a.c. unit is off.[/quote:50a0959f97]
Hello !!
Well I thionk that your problem its the IAC (idle air control valve/motor)
there are two idle speed adjustments to control idle on our cars. First is the manually adjusted base idle setting, which determines the minimum airflow through the IACV (and minimum warm-idle speed). Second is the ECU's control over the "trim" valve within the IACV, which compensates for hot and cold idle and engine loading (power steering and A/C operation).
I think that the Valve stick open once you turn on the A/C and stays that way..
Check that, clean it and replace it if faulty, be sure to adjust it ( it should be fully seated (the package should tell you the way it will be adjusted)
any other question do not hesitate to ask good luck and let us know if that solve your problem!
Jan 3, 2008 at 2:23 PM
