Our truck will not start. Electrically all accessories work and it turns over but no spark to the wires. Now battery weak so must jump to do testing. Good fuel flow. Scanning computer will not make a connection so I suspect a bad PCM. It trys to make a connection and requests the ignition to be turned on but then says no connection made.
I also wonder if there is an electrical wiring problem and how to track it down. No fuses are blown now but at one point the ignition fuse 40amp was blown and replaced. Some wiring was damaged on several aftermarket fog lamps and these were reworked. The car also has an aftermarket alarm system that seems to be working.
Nov 30, 2008 at 1:13 AM
