2000 Chevy Silverado brakes light
2000 CHEVROLET SILVERADO
66,000 MILES • V8 • 2WD • MANUAL
DROOPYS226
by brake lights do not work, but the one on the cab works. I check fuses and the bulbs and both of the are good. I checked the bulbs on both tail lights and they are good. I dont understand why the cab brake light works and the other two brake lights dont work.
Feb 3, 2009 at 9:17 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty brake light switch, located at top of brake pedal. This controls the two rear lower brake lights, does not effect the high mount cab brake light though. Test switch for power. If power is present at switch, it needs replaced.
Thanks for using 2CarPros.com!
Feb 3, 2009 at 10:18 PM
