1999 Chevy Silverado wheel speed module
1999 CHEVROLET SILVERADO
200,000 MILES • V8 • 2WD • AUTOMATIC
PIERRE BOISSONNEAULT
Sometime at 500 rpm or a little least , I am loosing my power brake. Could it be that one of the swheel speed module is gone. How much to replace it
Or what would the cause for this malfunction . Best regards Pierre
updated5/1/10
Alo Bob , Ken , I di what you have asked me cto do . I check the brake booster with a vaccuum pomp and \i tested it at 3, 5, 10, 15, and 20 inches and the booster was holding and no drop in vaccuum. Also check my check valve and when I took it off , there was a pressure so it is fonctioning properly. Now this problem is intermitante and does not occur every time I stop but only sometime when I back up or make some stop at low speed let;s say about 1 to 3 miles per hour . My rpm gage read between at iddle 500-700 rpm and when I put the trasnsmission in drive then itdrop down to 500 and sometime a littlelower then 450 rpm so what could be causing this problem . Could the dealerhook up a cpmputer and could the computer read the reason for this malfuctionning??? Well awaiting an answer or guidance from you Best regards, Pierre
Apr 26, 2010 at 9:20 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds liek you are losing vacuum due to teh low idle possibly.May also be a brake booster going away.You will need avacuum pump to t\est the booster to see if it is able to hold vacuum.Also verify the check valve where the vacuum line to the intake attaches to the booster working properly.
updated 5/8/10
Allo there, well my brake paddle stay on top and I beleve maybe I loose power brake, but I press really hard on the pedal and after a few secon it gab, so I will try from now on when I turn very slowly or when I have to drive very slowly before I stopped I wll put my transmissino into neutral and see if this does the same thing , What do you think????? Pierre
Apr 26, 2010 at 11:46 AM
2CARPRO JACK
  • 11,533 POSTS
Just to clarify, what exactly is happening to the brake pedal when it is idling that low'?
May 2, 2010 at 8:15 PM
2CARPRO JACK
  • 11,533 POSTS
sure give it a try and see what happens.The brake booster failing willmake the pedal hard and it will take alot of push on the pedal to stop the vehicle
May 10, 2010 at 2:33 PM
