1999 Chevy Silverado WANT START
1999 CHEVROLET SILVERADO
215,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOHN H PAGE
  • 6 POSTS
GOT WATER IN FUEL TANKS WOULD NOT START,CHANGE FUEL FILTER & PLUGS STARTED AND GOT HOME. WOULD NOT START. PUMPED OUT TANKS & CHANGED FUEL AGAIN & PLUGS STILL WILL NOT START
Feb 2, 2010 at 10:36 AM
2CARPRO JACK
  • 11,533 POSTS
Does it have fuel pressure? if so how much?. Will it fire up if you spray carb cleaner in the throttle bore? If you have pressure, ou should take a fuel sample at the engine to see what it looks like
Feb 2, 2010 at 3:20 PM
JOHN H PAGE
  • 6 POSTS
YES, PSI IS ABOUT 65, NO WHEN SPRAY WITH CARB CLEANER
Feb 8, 2010 at 9:10 AM
2CARPRO JACK
  • 11,533 POSTS
How about spark? those had problems with crank angle sensors, which would cause a loss of spark
Feb 8, 2010 at 11:32 AM
JOHN H PAGE
  • 6 POSTS
yes it has spark
Feb 8, 2010 at 11:52 AM
2CARPRO JACK
  • 11,533 POSTS
Thats odd, if it has spark, it should start with carb spray sprayed into it. May want to try that again. Check all fuses with a test light too.
Feb 8, 2010 at 9:44 PM
JOHN H PAGE
  • 6 POSTS
could it be some code in the computer that needs to be resit
Feb 9, 2010 at 9:10 AM
2CARPRO JACK
  • 11,533 POSTS
No, codes wont keep it from running.If it has spark out of the coil, be sure it has it at the plugs.
Feb 9, 2010 at 1:04 PM
