1999 Chevy Silverado Put it into drive an it shakes an hurt
1999 CHEVROLET SILVERADO
LOBO667
Transmission problem
1999 Chevy Silverado V8 Four Wheel Drive Automatic ? miles
Im in some need of help, Ive received a 99 silverado 2500 that came from my brother. The truck shifts hard and shrugs while accelerating in Drive ... Its like the ass cant keep up..? You can manually shift 1-2-3-Drive to highway speed, but to move in low rpms it shudders hard. You can feather the gas pedal to make it work but if you had to punch it the truck would chatter an not shift..?? Ive heard that a trans filter replacement will help, to a whole trans replacement . Still not sur. I want to make it work and keep it around.
Oct 26, 2010 at 10:56 PM
When you put it in drive, will it shift on its own?
Nov 1, 2010 at 11:30 AM
LOBO667
It will shift in drive if you work the pedal. Had to change oxygen sensor for smog and it seems to make it worse. Sensors bad somewhere else?Im kinda at a stand still. Its a good project, never know whats next. Thanks for the replys
Nov 6, 2010 at 3:04 PM
It sounds like a problem with the shift solenoids. If you are able to make it shift, that is my first guess.
Nov 6, 2010 at 3:30 PM
LOBO667
This sounds like something in the trans and might be something out of my league. what intails changin em and if I go that far should the tranmission be rebuild?
Nov 10, 2010 at 9:17 PM
