1999 Chevy Silverado Power seat issues
1999 CHEVROLET SILVERADO
286,000 MILES • V8 • 2WD • AUTOMATIC
GOTECHSLACK
  • 7 POSTS
Hello. I am having an issue with my power driver's seat. I have the stated truck. The driver's side, bucket seat, powers back and forth, but not up and down (vertically). Does this mean that the seat motor needs replacing? If so, is it a difficult job to replace and where can I get the part? Thanks.
Feb 1, 2010 at 1:46 PM
JDL
  • 16,098 POSTS
hi, Do the seat controls look like the picture? I'd have to check the wiring circuits before I could say about the motor. The switch is another possibility.
https://www.2carpros.com/forum/automotive_pictures/170934_silverado_power_seats_1.jpg
Feb 1, 2010 at 3:16 PM
GOTECHSLACK
  • 7 POSTS
No. It only has the horizontal seat control. The horizontal seat control can be moved up and down on both the front and rear, of the control. Like I said, it works fine moving back and forth (horizontally), but when I move the control up or down, I can hear the motor, but it appears too "weak" to move the seat up/down. Hope this help. Thanks for your help.
Feb 1, 2010 at 3:48 PM
JDL
  • 16,098 POSTS
I see, it sounds like the motor. I'd still want to check the circuits, though.
Feb 1, 2010 at 4:14 PM
GOTECHSLACK
  • 7 POSTS
Ok. Thanks. Wiring circuits? Any instructions would be very helpful. Thanks again.
Michael
Feb 1, 2010 at 4:19 PM
JDL
  • 16,098 POSTS
I'd remove the seat, go from there. If you can reach the motor connector without removing the seat, you can try that. For testing, you might be able to use jumper wires for voltage and ground, using inline fuse, to see if the seat will operate properly, if it does, the problem isn't the motor. If it does the same old thing, then I suspect the motor. Just to add, feel of the power seat circuit breaker, see if it feels hot, when trying to raise the seat. I believe the circuit breaker is 25 amp.
Feb 1, 2010 at 4:29 PM
GOTECHSLACK
  • 7 POSTS
Great info, thanks so much. The motor is near the front of the seat, so I think I can get to the connectors. So, try to jump the motor to see if it operates properly and feel the circuit breaker to see if it is warm? Would the circuit breaker/fuse be near the motor? Thanks again.
Feb 1, 2010 at 5:57 PM
JDL
  • 16,098 POSTS
I've been checking, probably not a good idea for you to diagnose. Under the driver seat there is an airbag module, that you don't want to fool with and three motors for the seat. You might be able to look at the power switch for the seat. You still need to disarm the airbags before you do anything. I don't advise using jumper wires on anything.
Feb 1, 2010 at 6:47 PM
