driverside frame rail, Threaded fitting on both ends, need a couple of wrenches. As far as pressure, after the vehicle sits overnight without the key being cycled or engine started, there usually isn't much pressure. A fuel pressure gage has a bleedoff valve on it, bleed into a container, or make sure the pump is disconnected, start the the vehicle, when it dies the pressure should be gone. That doesn't mean gas won't drain from the lines, take gas cap off. Sometimes I'll plug the gas lines with something till ready to go back with new filter. If you use a droplite don't lay it where gas might drip on it.
Sep 10, 2020 at 12:24 PM
(Merged)
