1999 Chevy Silverado fuel pressure
1999 CHEVROLET SILVERADO
154,000 MILES • V8 • 4WD • AUTOMATIC
SNOBRDRPRO
  • 55 POSTS
my truch has a hard time starting if i try to start it right off the bat. but if i let the fuel pum build some pressure itll start, so i hooked up the pressure guage and turned the pump on and it went up to 15psi then down to zero, then i tuned the engine on and i ujusted the regulator to the correct psi.And when i turned the truck off it went back to zero psi. is this a pump or a regulator problem?
-thanks to all
Apr 6, 2009 at 12:34 PM
That fuel pressure is way too low. It should have been 60-66psi
If pressure drops quickly, the vehicle may have a leaky fuel line, a leaky fuel pump check valve, a leaky fuel pressure regulator or one or more leaky fuel injectors.
Apr 6, 2009 at 12:48 PM
SNOBRDRPRO
  • 55 POSTS
I can adjust the fuel regulator to 66 psi I'm just wondering what's causing it to drop to zero
Apr 6, 2009 at 3:01 PM
One of the above will drop the fuel pressure
Apr 6, 2009 at 4:18 PM
SNOBRDRPRO
  • 55 POSTS
Is there anyway I can check them? I just recently(maybe 7-8 months ago) got a new pump. How do I fix an injector leak? New ones?
-thanks for your help
Apr 6, 2009 at 5:42 PM
Is there anyway I can check them? By doing a few pressure drop by activating it one at a time-your best is just replace it
Apr 6, 2009 at 6:10 PM
SNOBRDRPRO
  • 55 POSTS
What should I replace?
Apr 6, 2009 at 9:33 PM
Honestly sir-I don't want you to throw parts at it till its fix-reading your 1st post I'll replace the fuel pump if it was me. The fuel pump should hold pressure for a period of time not just drop to zero as you stated.
Apr 7, 2009 at 12:08 AM
SNOBRDRPRO
  • 55 POSTS
Ok that's not a problem as the fuel pump is on a warranty, could it also be the regulator?
Apr 7, 2009 at 12:11 AM
Yes sir could be the regulator if its ruptured and not maintaining the fuel pressure
Apr 7, 2009 at 12:36 AM
SNOBRDRPRO
  • 55 POSTS
Ok is there anyway I can test these to see which one it could be?
Apr 7, 2009 at 12:38 AM
This what I want you to do-pinch off the return line hook up the fuel pressure gauge turn key on and monitor the pressure it should increase considerably over the specified fuel pressure specs.
Do you have a TBI or MPFI fuel system? At the pressure regulator do you have a vacuum hose connected to it. If so look inside if it has fuel if so the regulator is defective
Apr 7, 2009 at 12:55 AM
SNOBRDRPRO
  • 55 POSTS
Ok I will try that. And I'm not sure what system I have. Should I pinch the hose while it's running or with just the key on?
Apr 7, 2009 at 12:58 AM
Do it while its running
Apr 7, 2009 at 12:59 AM
SNOBRDRPRO
  • 55 POSTS
Ok will do. I'll give you a word tomorrow
Apr 7, 2009 at 1:01 AM
