my truch has a hard time starting if i try to start it right off the bat. but if i let the fuel pum build some pressure itll start, so i hooked up the pressure guage and turned the pump on and it went up to 15psi then down to zero, then i tuned the engine on and i ujusted the regulator to the correct psi.And when i turned the truck off it went back to zero psi. is this a pump or a regulator problem?
-thanks to all
-thanks to all
Apr 6, 2009 at 12:34 PM
