1999 Chevy Silverado brake lights
1999 CHEVROLET SILVERADO
110,000 MILES • V8 • 4WD • AUTOMATIC
MICHAEL D KUBITZ
i have checked fuse and replaced switch at pedal and still no lbrake lights.it has factory tow pacage and about evey other option. where might the problem be?
Apr 30, 2010 at 8:42 AM
INTERNETMECHANIC
  • 700 POSTS
Does the highmount brakelite work? If not, check voltage feed to and from brake switch, use a voltage tester. Orange wire is hot all the time, feed to brake switch. White wire goes hot when brake switch is activated, voltage for brake lites.
If the highmount brake lite works and the lower ones don't, I check the feed from the multifunction switch.
Apr 30, 2010 at 9:37 AM
