1999 Chevy Silverado battery
1999 CHEVROLET SILVERADO
BUTCHHUNT
Electrical problem
1999 Chevy Silverado V8 Four Wheel Drive Automatic
when you unhook neg. battery cable it sparks is this normal ???
also changed alt. and gauge shows charging properly
but battery light shows up on massage center..
Aug 31, 2008 at 6:53 PM
BLACKOP555
  • 10,386 POSTS
yes its normal if the connection is removed then reapplyed.
does teh battery light turn on vehicle running and all? or just with key on engine off?
Aug 31, 2008 at 8:41 PM
BUTCHHUNT
[quote:6a15880428="blackop555"]yes its normal if the connection is removed then reapplyed.
does teh battery light turn on vehicle running and all? or just with key on engine off?[/quote:6a15880428]
when you trun key the light is on then it goes out but comes back on when you start to drive it..
replaced alt. with new one and parts store said it will be on for 15 - 20 miles but drove it and light still on ??
Sep 1, 2008 at 9:45 AM
BLACKOP555
  • 10,386 POSTS
have you tryed a different battery? a bad one can cause the alternator to put out too much power and it will burn right up.
Sep 1, 2008 at 3:39 PM
BUTCHHUNT
[quote:3437cd1acd="blackop555"]have you tryed a different battery? a bad one can cause the alternator to put out too much power and it will burn right up.[/quote:3437cd1acd]
battery test good with every test that you can do on a battery.. had no problem until needed to replace alt..
Sep 1, 2008 at 6:10 PM
BLACKOP555
  • 10,386 POSTS
could be a bad alternator. try a better brand of one and test the voltage off of it directly see if its putting it out or if its putting out 0 charge.
Sep 1, 2008 at 6:37 PM
