I have seen this before it ended up being the ECM causing the issue.
Here is how the book says to set the timing.
Set parking brake, block drive wheels and place transmission in Neutral or Park.
Warm engine to normal operating temperature.
Turn A/C off (if equipped).
Ensure Malfunction Indicator Light (MIL) is not on.
Disconnect Tan/Black Electronic Spark Timing (EST) by-pass connector wire located near distributor or under the dash in the center or by the passengers side.
EST connector is located inside cab right side by heater motor, not under the hood, 1994 and up).
DO NOT disconnect 4-wire connector at distributor.
Connect timing light to No. 1 spark plug wire.
Check timing and adjust if necessary.
Reconnect EST by-pass connector, and clear ECM trouble code
Timing should be set at 0 and at idle When throttle is open timing should change as this is normal check timing chain and fuel pressure.
Cheers
Aug 22, 2020 at 9:26 AM
(Merged)
