how do you adjust the lifters and how tight do you tighten the nut of the rocker arms
Aug 8, 2010 at 5:49 PM
HMAC300
CERTIFIED EXPERT
they are hydraulic and need no adjustment unless you have replaced something. But if you need to adjust htem, then the procedure is bring #1 to TDC and take lash out of lifter and then 1 ful turn down. Continue the rest of the way throughout the engine with each cyllinder.
