i was driving the other day and my ABS system started going crazy..after turning engine off and on it was reset, but an hour later it did it again, along with my transmission jumping between 3-4 gears...later all the above happened, but tranny started jumping from 4 to 2-3-1 gears (very erratic) and the speedometer jumps to different speeds even though im going 30-40 mph...come to find out my intake manifold gasket was leaking pretty bad...could coolant leakage cause a sensor to go bad causing these problems?? any input would be appreciated.
Feb 13, 2006 at 4:54 PM
