1996 Chevy Silverado signal lights
1996 CHEVROLET SILVERADO
156,700 MILES • V8 • 2WD • AUTOMATIC
GENE PAYNE
Hello Help, where is the signal relay on the 1996 chevy p/u?
Is there a turn signal relay or a breaker device?
Also will a locking rear-end chatter at low speeds when slight turns are made?
Thanks, Gene
Mar 18, 2008 at 6:46 PM
MASTERTECHTIM
  • 4,750 POSTS
the rear end will chatter if the fluid is dirty and or no posi additive had been added. my suggestion is to change fluid and add posi additive to get rid of shudder. the flasher module is located in the convenience center under left side of dash panel. hope this helps
Mar 18, 2008 at 6:52 PM
