When I turn the fan on you can hear it running but the air flow seams to be comming out of all the openings. You never get that blast to the windshild, dash vents, or floor. Maybe a little more comes out when you adjust to 1 of those settings. It heats or cools fine, it just takes a while. as it seems like the air comes out all the opens. Where should I start? I've always wondered if something fell down the defrost opening and is blocking something, although Ican't heat any vaccum noise when changing between the openings.
Jun 20, 2010 at 10:16 PM
